imahawki
Dec 01, 2011Aspirant
Ultra 6 configuration question
I have been doing heavy, heavy research for a couple weeks on how to store a fairly large amount of data (2-3TB) and back it up with the ability to take the backups off-site so I don't lose everything...
yoh-dah
Dec 01, 2011Guide
imahawki wrote: I would like to buy an Ultra 6 and configure it with two separate pools of 3 disks. One as live data and the other as backup. The reason I want the pools separated is because I want the 3 drives that are the backup to be able to be swapped out. So, will this work?
That's not recommended as the SATA connectors are not rated for constant swapping. It's better if you consider something like http://www.readynas.com/replicate .
- Sep 19, 2018Retired_Member
