Rubatoguy
Mar 15, 2013Aspirant
Ultra Nas 6 with 3 WD 3TB drives only shows 5.5TB
Hello, I just got an Ultra Nas 6 to replace my NV+ and have equipped it with 3 WD red 3tb drives, however, rather than somewhere near 9TB available, it only shows 5.5TB available.... That seems like...
Mar 16, 2013Guru - Experienced User
That is expected, you can test it with the calculator. To approximate the space, take away the largest drive and sum the rest (3x2TB=6TB, 2x3TB=6TB).
Rubatoguy wrote: Your reply makes sense. Thanks! Interesting that I ended up with about the same usable space with 4 2tb drives in my NV+ and 3 3tb drives in the Ultra 6.
Well, you could of course try the calculator... :shock: 6x3TB-> about 15 TB, 6x2TB-> about 10 TB.
Rubatoguy wrote: So, given the formula, if you were to fill all 6 drives in the Ultra 6, what drive size would give you the most useable space?
