Shawinkle
May 18, 2024Aspirant
Ultra2 stops working after boot
Hello. My RNDU2220 works fine since.... a lot of years Last month, after a long global power outage (UPS out of battery), the NAS runs strangely. It hangs just after the boot. Here's a sample o...
May 18, 2024Guru - Experienced User
What firmware was the system running?
Do you have a backup for the files on the NAS?
- ShawinkleMay 18, 2024Aspirant
I don't really remember... 4.2.26 or 4.2.29.
I tried to "reinstall the OS" via the boot menu, but nothing happen.
And I don't plan to lose data.
- StephenBMay 18, 2024Guru - Experienced User
The NAS says it is shutting down, but you are still getting information via ssh?
Does that mean that the NAS is still running, but that the shares (and frontview) are not available?
If so, is the data volume still mounted?
- ShawinkleMay 18, 2024AspirantI just have the time to connect during the boot through a SSH connection (with private key), and to copy (with scp command) some log files.
The volumes seems to be mounted. All the shares are available.
