bthom70
Feb 05, 2011Aspirant
Ultra4 fan speeds
I'd like to have a way to manually control or limit the fan speed for my Ultra4. 1804RPM is just too loud in my living room, I can tolerate 1650RPM. I've tried running the recalibrate utility abou...
demusss1
Oct 01, 2011Aspirant
You might find that the noise is coming from the psu fan. I have an ultra 4 plus and the psu has a 40mm fan which is not speed controlled and is quite noisy.
You might the thread I started.
I've resorted to just hiding it in a cupboard.
