crond
Nov 28, 2015Aspirant
Ultra4 (OS4) is dead what's the best way to get disks back online ?
Dear All, Not sure what would be the best place for this discussion, but since the easiest way for me will be to buy a new unit I think HW compatibility is the right starting point. A short...
- Nov 29, 2015
No, the Ultra 4 does not use the supply listed by StephenB, the Ultra 6 and 6-bay Pro models do.
The NV+, NVX, and Ultra4 all use the same power supply, with the pin-out as shown here: http://www.readynas.com/download/archive/pdf/ReadyNAS_PSU_pinout.pdf. I assume the 4-bay Pro's do as well, but I've never had one. It appears to me to be nothing more than a differently wired Mini ITX supply, which is readily available for under $40. The ratings on the one from my parted out NVX are +3.3V @ 8A, +5V @ 8A and +12V @ 7A. It even lists the -5 and -12V's on the label, which even more leads me to believe it's just a specially wired standard supply with the fan removed (even has a spot for the removed fan, and my original NV did have the fan installed.. a 150W supply should be more than enough, and NewEgg currently has a $10 rebate on a $39 one.
Before you are sure it's the power supply, you could do the "paper clip test" on the existing one. The on/off being a "soft" one, a motherboard issue could cause failure to power on, too. The voltages may not be quite right with no load, but it can be of some help in verifying the issue is the power supply. If it is the supply, you can use this info to do a temporary external install of an ATX supply just for files recovery or you could try the Mini ITX one.
Nov 29, 2015Guru - Experienced User
Ultra and Pro ReadyNAS use standard pinouts, so there is no need to modify the wiring.
Posters here have replaced the PSU with a SeaSonic SS-300SFD SFX supply, though they also have indicated that a short 24-pin extender cable is needed. One other poster said he also used a sata to molex adapter. You can search the forum for the details.
I haven't done this myself, but the parts are readily available, and inexpensive (~$50 US total)
http://www.newegg.com/Product/Product.aspx?Item=N82E16817151089
http://www.newegg.com/Product/Product.aspx?Item=N82E16812816038
Amazon also carries them all.
- SandsharkNov 29, 2015Sensei
- StephenBNov 29, 2015Guru - Experienced User
Sorry, I apologize for providing the wrong information.
- crondNov 29, 2015Aspirant
Thanks for information on pinout, yeah will do the test before ordering something expensive :)
If it's PSU will start with extendar I have couple ATX PSU I can play with.
