mopgcw
Sep 06, 2015Aspirant
ULTRASTAR HE8 8TB
FWIW, these have been running fine for two weeks now in a 716..model: HUH728080ALE600 / 0F23267
ifixidevices
Nov 20, 2015Luminary
StephenB wrote:
mdgm wrote:The guide is mentioned in our instructions as to be used with 3.5" drives. Qualifying a disk where this can't be used would confuse things.
Understood.
I think the bigger question is whether a 3.5" drive is safely mounted if you don't use the guide. I'm thinking it's provided for a reason.
I took the guide out of my RN516 trays and am using them with the 8TB seagates using only two screws out of the 4 (sucks but it's still mighty secure in the drive tray.)
Nov 20, 2015Guru - Experienced User
I think Netgear clarified that was ok after my post - don't recall exactly where.
- ifixidevicesNov 20, 2015Luminary
Yeah it should be seeing as to how you have to take the tray out for 2.5" drives. It's really a nifty system over screws but realistically you're not constantly taking and removing and installing drives so the little bit extra time to use a screwdriver over the slider tray isn't that big of a deal. Only thing I cringe at is those who shear the middle nub off the tray. Yes it works but later on when drives end up having those holes again it's going to stink as you can't put them back on (unless you have plastic weld and a clean break!)
- StephenBNov 20, 2015Guru - Experienced User
ifixidevices wrote:
...Only thing I cringe at is those who shear the middle nub off the tray.
Me too. Taking out the guide and using screws is much better.
