mopgcw
Sep 06, 2015Aspirant
ULTRASTAR HE8 8TB
FWIW, these have been running fine for two weeks now in a 716..model: HUH728080ALE600 / 0F23267
ifixidevices
Nov 20, 2015Luminary
Yeah it should be seeing as to how you have to take the tray out for 2.5" drives. It's really a nifty system over screws but realistically you're not constantly taking and removing and installing drives so the little bit extra time to use a screwdriver over the slider tray isn't that big of a deal. Only thing I cringe at is those who shear the middle nub off the tray. Yes it works but later on when drives end up having those holes again it's going to stink as you can't put them back on (unless you have plastic weld and a clean break!)
Nov 20, 2015Guru - Experienced User
ifixidevices wrote:
...Only thing I cringe at is those who shear the middle nub off the tray.
Me too. Taking out the guide and using screws is much better.
