mopgcw
Sep 06, 2015Aspirant
ULTRASTAR HE8 8TB
FWIW, these have been running fine for two weeks now in a 716..model: HUH728080ALE600 / 0F23267
mdgm-ntgr
Sep 06, 2015NETGEAR Employee Retired
Nice.
Did the drives fit fine in the drive trays or did you have to leave a tab out or modify the tray to get the drive to fit?
Do note that if you run into issues using drives outside the compatibility list then support may refuse to help. So if you are using the NAS for primary storage it is even more important than it would be otherwise to backup your data regularly.
mopgcw
i had to remove the black plastic interior guide of the tray, but then they fit right in.
- mdgm-ntgrSep 06, 2015NETGEAR Employee Retired
mopgcw wrote:
i had to remove the black plastic interior guide of the trayUnfortunately with that limitation I don't think we can qualify them. We need disks to fit into the tray to be able to qualify them.
- StephenBSep 07, 2015Guru - Experienced User
mdgm wrote:
Too bad really, as they are the only 8 TB drive suitable for NAS. They are pricy though, so I don't think many users would consider them.
- mopgcwSep 07, 2015AspirantThey are a bit pricey indeed, and i am not sure how the whole "sealed helium" is going to workout in the long run. but in combination with the 716 i have to say, it seems to be working like a champ, quick and roomy.
- mopgcwSep 07, 2015Aspirantiirc, isn't one required to remove the plastic guide depending on if it is 2.5" or 3.5" drive? i seem to recall that from the instructions.
