mopgcw
Sep 06, 2015Aspirant
ULTRASTAR HE8 8TB
FWIW, these have been running fine for two weeks now in a 716..model: HUH728080ALE600 / 0F23267
mopgcw
Sep 07, 2015Aspirant
Thanks, Stephen, that is what i thought. so, it does fit fine since that "part" is optional anyway to the function, so really dont see a barrier to qualifying the drive. but regardless, will keep you posted if any issues pop up. best, George
mdgm-ntgr
Sep 07, 2015NETGEAR Employee Retired
The guide is mentioned in our instructions as to be used with 3.5" drives. Qualifying a disk where this can't be used would confuse things.
- StephenBSep 08, 2015Guru - Experienced User
Understood.
I think the bigger question is whether a 3.5" drive is safely mounted if you don't use the guide. I'm thinking it's provided for a reason.
- jtclarkNov 05, 2015Aspirant
I had already removed the middle "nub" from the guide for a prior drive model.
With that minor modification these drives fit using the guide.
Next time I power down I'll look a little closer.
- jtclarkNov 06, 2015Aspirant
I had trimmed the middle post out of the guide because the Seagate Drives I had been using did not have a screw hole for that "nub".
Having looked a little closer, the HUH728080ALE600 will fit into the tray with no modification to the guide.
- ifixidevicesNov 20, 2015Luminary
StephenB wrote:
mdgm wrote:The guide is mentioned in our instructions as to be used with 3.5" drives. Qualifying a disk where this can't be used would confuse things.
Understood.
I took the guide out of my RN516 trays and am using them with the 8TB seagates using only two screws out of the 4 (sucks but it's still mighty secure in the drive tray.)
- StephenBNov 20, 2015Guru - Experienced User
I think Netgear clarified that was ok after my post - don't recall exactly where.
Yeah it should be seeing as to how you have to take the tray out for 2.5" drives. It's really a nifty system over screws but realistically you're not constantly taking and removing and installing drives so the little bit extra time to use a screwdriver over the slider tray isn't that big of a deal. Only thing I cringe at is those who shear the middle nub off the tray. Yes it works but later on when drives end up having those holes again it's going to stink as you can't put them back on (unless you have plastic weld and a clean break!)
ifixidevices wrote:
...Only thing I cringe at is those who shear the middle nub off the tray.
Me too. Taking out the guide and using screws is much better.
