DaBouncer1
Feb 25, 2022Tutor
Unable to access ReadyNAS NV+ v1 admin from RAIDar
Unable to access admin, not matter if I try via Setup button in RAIDar or from a saved favorite in Chrome. http://192.168.1.252/admin/ I get ERR_SSL_VERSION_OR_CIPHER_MISMATCH and the addres...
DaBouncer1
Feb 28, 2022Tutor
Thank you very much! Used the Internet Explorer-mode method and got access.
Guess it's about time to start looking for a newer NAS ;)
satpalmatta
Mar 30, 2022Aspirant
same problem while accessing data over ftp.
Error: "GnuTLS error -8: A packet with illegal or unsupported version was received."
Is there any workaround for the same.
- StephenBMar 30, 2022Guru - Experienced User
What FTP client are you using?
Were you trying to connect with normal FTP (which is unencrypted)? Or were you trying to use FTPS or SFTP?
