kontech
Mar 01, 2021Aspirant
Unable to manage NETGEAR ReadyNAS 3138
A new NETGEAR ReadyNAS user here just purchased NETGEAR ReadyNAS 3138. Device appears to be online, can ping its IP but cannot manage it via URL: https://IP address/admin. ReadyCloud is'nt finding i...
Mar 02, 2021Guru - Experienced User
Do you have disks installed? What is the status of the health LED on the front panel?
If this is a new NAS (not pre-owned) then you are entitled to installation support via my.netgear.com.
kontech
Mar 02, 2021Aspirant
I've tried with a and w/o disks and different Ethernet ports. The power and LAN LEDs have been flashing (green).
After pushing reset button with a pin power LED is now solid green I was ablet to get in.
It's a brand new device. Firmware 6.10.4
Any ideas what the problem could have been?
- StephenBMar 02, 2021Guru - Experienced User
kontech wrote:
I've tried with and w/o disks
Linux and the NAS application are installed onto the disks. So you can't access the web ui if disks are not installed.
There can be a "dead" time when the NAS is first installing the OS onto the disks. So that is one possibility - but I really can't tell if that was the cause or not.
