cmajewsk
Oct 01, 2006Aspirant
Unable to mount/format USB Drive
I changed the name of the USB drive within the RN 600 and now it will let me see it but not mount/use it. I connected it to a Windows 2000 machine and it sees it fine and the files there. Model: ...
cmajewsk
Oct 04, 2006Aspirant
When you say, "try your USB drive again" what exacly do you want me to? Unplug it, and replug it in, reboot the RN after that, then try and format? Any specific steps you want me to follow?
Thanks,
cmajewsk
Thanks,
cmajewsk
