cmajewsk
Oct 01, 2006Aspirant
Unable to mount/format USB Drive
I changed the name of the USB drive within the RN 600 and now it will let me see it but not mount/use it. I connected it to a Windows 2000 machine and it sees it fine and the files there. Model: ...
bobb1
Oct 24, 2006Aspirant
I am having the SAME exact problem as cmajewsk.
Ready NAS 600
Firmware: RAIDiator™ v3.00c1-p2
I changed the name of my USB drive. Since that time, I see it in Front View, under Volumes/USB Storage. It states the following USB device is connected. Light is green. My dropdown choices are Locate, Format FAT32, Format EXT3. None of these options work when GO is clicked.
On the shares list page, I see the following:
No USB shares exist. Plug in a USB storage device and click Refresh to display a USB share.
I have tried unplugging and replugging in the USB drive. Nothing seems to work.
I so not see a solution above so I will send my logs!
Thanks,
Bob
Ready NAS 600
Thanks,
Bob
