cmajewsk
Oct 01, 2006Aspirant
Unable to mount/format USB Drive
I changed the name of the USB drive within the RN 600 and now it will let me see it but not mount/use it. I connected it to a Windows 2000 machine and it sees it fine and the files there. Model: ...
cmajewsk
Oct 25, 2006Aspirant
I was kinda hoping someone else would have this issue...sorry...
I am using a Western Digital 200GB SE Drive and an Vantec Nexstar 3 USB as it's listed in their compatibility chart. I have been using this for over a year now, and had no issues until I upgraded the RAIDiator image to version 3 and renamed the drive.
I have been working with Infrant and thus far no solution. I have plugged in a USB flash drive to the ReadyNAS USB port(s) and it works fine. I have plugged the Vantce drive enclosure into a few different PC's and it also mounts and works fine. They had me format the drive :( which I did and still the same thing happens. I have sent the logs multiple times, most recently when I inserted the Vantec to the ReadyNAS.
Anyone else seeing this?
