cmajewsk
Oct 01, 2006Aspirant
Unable to mount/format USB Drive
I changed the name of the USB drive within the RN 600 and now it will let me see it but not mount/use it. I connected it to a Windows 2000 machine and it sees it fine and the files there. Model: ...
cmajewsk
Oct 26, 2006Aspirant
Han Solo wrote: cmajewsk,
Can you try formating your USB drive using the following,
http://www.mager.org/mkdosfs/
Let me know if this helps. If you have any questions let me know.
Sure not a problem, I'll try that tonight. BTW, just confirming that you know it's a standard EIDE drive in a USB enclosure.
Many thanks,
cmajewsk
