cmajewsk
Oct 01, 2006Aspirant
Unable to mount/format USB Drive
I changed the name of the USB drive within the RN 600 and now it will let me see it but not mount/use it. I connected it to a Windows 2000 machine and it sees it fine and the files there. Model: ...
Han_Solo
Oct 28, 2006Tutor
bobb wrote: I tried reformatting the drive as well using the program above. Same issue, the drive shows up under Volumes/USB - green light etc as described above but not on the shares page in Frontview.
Bob
Hi Bob,
If you could please send me all your logs to me. I want to see if it is the same thing that cmajewsk reported. If you need info on how to send all logs look below. Also, please insert Attn: Han Solo in the subject line. Thanks.
http://www.infrant.com/forum/viewtopic.php?t=1140
