cmajewsk
Oct 01, 2006Aspirant
Unable to mount/format USB Drive
I changed the name of the USB drive within the RN 600 and now it will let me see it but not mount/use it. I connected it to a Windows 2000 machine and it sees it fine and the files there. Model: ...
Han_Solo
Dec 13, 2006Tutor
We were able to resolve cmajewsk problem. It turned out that when the USB drive was renamed a space was accidentally included. This caused the USB drive not to mount properly. The newer release p5 should not allow spaces for a USB drive name. If someone is using an older release either upgrade or just remember to check for any spaces when renaming a USB drive.
