cmajewsk
Oct 01, 2006Aspirant
Unable to mount/format USB Drive
I changed the name of the USB drive within the RN 600 and now it will let me see it but not mount/use it. I connected it to a Windows 2000 machine and it sees it fine and the files there. Model: ...
PapaBear1
Jan 10, 2012Apprentice
fixmacs - that is an old thread and maybe the reason that ScuseMe "disappeared" is that is post is almost two years old. I would suggest you start your own, describing your equipment and exactly what problems you are having. You are far more likely to get a response. Many people skip over the discussions that go on for pages and started years ago. They are not so relevant today as there have been several versions of Frontview released in the interim.
