cmajewsk
Oct 01, 2006Aspirant
Unable to mount/format USB Drive
I changed the name of the USB drive within the RN 600 and now it will let me see it but not mount/use it. I connected it to a Windows 2000 machine and it sees it fine and the files there.
Model: Infrant ReadyNAS 600
Firmware: RAIDiator™ v3.00c1-p2 [1.00a131]
USB Storage Devices
The following USB storage devices are connected. Unmount the device if you wish to rename it.
If I try to Format FAT or EXT3 - nothing happens. I hit the "GO" button and then nothing. Even apply does not un-gray out. Any Ideas? It sees it - it's posintg a green light within the USB tab under Volumes. If I select any option and hit "GO" nothing will happen, however it I select another menu in the Frontview it will tell my my changes were not applied.
Device Part Description Disk Used Capacity File System
TertiaryOffsite - WDC WD20 00JB-00DUA0 - 186 GB No Filesystem OptionsLocateFormat FAT32Format EXT3
USB Storage Devices
- fixmacsGuideYour suggestion is valued. I will follow up. Many thanks.
