mbkitmgr
May 24, 2012Aspirant
Unable to remove partialy seated drive caddy
I have a RND4000 with 4 disks installed. I needed to check the model/serial number of one of the drives, removed the Drive+Caddy and when I went to re-insert the drive+caddy, it locked before fully s...
mdgm-ntgr
May 24, 2012NETGEAR Employee Retired
Take a look at http://www.readynas.com/kb/faq/hardware/how_can_i_release_a_stuck_disk_tray
For future reference when checking the model/serial number of drives you don't need to remove them to check them. In the v1 (which I presume is what you have based on your forum join date) you'd go to Status > Health in Frontview and click on the SMART+ button next to the drive.
