mbkitmgr
May 24, 2012Aspirant
Unable to remove partialy seated drive caddy
I have a RND4000 with 4 disks installed. I needed to check the model/serial number of one of the drives, removed the Drive+Caddy and when I went to re-insert the drive+caddy, it locked before fully s...
ReadySECURE
May 24, 2012Apprentice
It is very hard to describe in text so here is a video. If you have trouble with the hole he is using, try the one just to the right.
