mbkitmgr
May 24, 2012Aspirant
Unable to remove partialy seated drive caddy
I have a RND4000 with 4 disks installed. I needed to check the model/serial number of one of the drives, removed the Drive+Caddy and when I went to re-insert the drive+caddy, it locked before fully s...
mbkitmgr
Thanks for the info - neither worked. The hole isnt accessible either way. A close inspection of the latch mechanism on the other caddy allowed me to work out how to get at the latch mechanism another way.
Sorry for my attititude in this post - I work with several different vendors in SMB and Enterprise arena's and I find it frustrating when you need support from NetGear. It has really opened my eyes
