mbkitmgr
May 24, 2012Aspirant
Unable to remove partialy seated drive caddy
I have a RND4000 with 4 disks installed. I needed to check the model/serial number of one of the drives, removed the Drive+Caddy and when I went to re-insert the drive+caddy, it locked before fully s...
ReadySECURE
May 24, 2012Apprentice
I am sorry to hear that it has been giving you such a hassle. Would you be able to share the other way that you got to the latch?
