mbkitmgr
May 24, 2012Aspirant
Unable to remove partialy seated drive caddy
I have a RND4000 with 4 disks installed. I needed to check the model/serial number of one of the drives, removed the Drive+Caddy and when I went to re-insert the drive+caddy, it locked before fully s...
mdgm-ntgr
May 24, 2012NETGEAR Employee Retired
It should also be noted that new models now come with a tray with a rectangular button. The newer trays don't run into this issue.
