ulfrickardsson
May 06, 2023Aspirant
Unable to start RN31400 NAS
Suddenly I get no response from my NAS RN314000. I can find that it gets an IP but I cant find it in Raidar and I cant access the IP-adress. Is there a way to get the data?
May 07, 2023Guru - Experienced User
ulfrickardsson wrote:
Actually I can access the NAS if I remove the disks, It also shows its a new disk so I guess that my "USB Recovery Tool" did some effects.
if i start the NAS with the disks the fan never stops (days) ant the green diode always blinks.
So what would be the next step?
I would test the disks in a Windows PC using vendor tools (Seagate's Seatools, WD's Dashboard or Lifeguard).
ulfrickardsson
May 10, 2023Aspirant
Hello
I have downloaded "ReclaiMe" and can see one drive when connected to my pc.
Is there a way I can connect the NAS directly to my pc so I can access the all the disks? Or do I have to buy 4 external hdd-adapters?
- StephenBMay 10, 2023Guru - Experienced User
No.
You can get multi-bay docks - about $100 USD for most 4-bay docks, about $45 for 2-bay.
