wideef2
May 28, 2013Aspirant
Unbearable FAN NOISE on Readynas NVX business edition
Hello. We've got a 80% full Readynas NVX business edition running in x-raid2 (4.2.23) and we're just evaluating upgrade paths. We've purchased 4 higher capacity drives that are on the Netgear HCL b...
wideef2
thank you for the quick reply. as the add-on is not listed under installed devices is there any other way to check to see if it is still present on the nvx? better it comes off by the sound of things.
also would you have a link to where we'd need to contact support please?
