Martint92
Jul 20, 2017Aspirant
Understanding ReadyNAS OS
I've been looking around on the site and forums for awhile and unable to find the answer to my questions. For context, I work for a small firm that is trying to go digital for all their files. On...
Sandshark
Jul 21, 2017Sensei
I believe that adding ZeroTier to the NAS and PC will provide the most transparent solution. Search the forum for NASTools' app version for the ReayNAS. ZeroTier provides a VPN which runs in parallel with the standard network connection, not instead of it. Once installed, you can map a drive using the NAS's ZeroTier IP address and it will work seamlessly locally or remotely and without affecting other local network resources.
