Martint92
Jul 20, 2017Aspirant
Understanding ReadyNAS OS
I've been looking around on the site and forums for awhile and unable to find the answer to my questions. For context, I work for a small firm that is trying to go digital for all their files. On...
Jul 24, 2017Guru - Experienced User
I use openVPN myself for remote access (it is built into my Orbi router). You can use ZeroTier in a similar way - both methods allow the remote PC to access the NAS as if it were on the local network.
ReadyCloud doesn't quite do that, especially if you use the NAS "home" folder for local accounts. The remote ReadyCloud account isn't the same as the local use account, and they can't be linked. So I think ZeroTier/OpenVPN are better matched to what you have in mind.
aks wrote:
For access outside your network, you need to consider how the remote machine will find your NAS inside your network (typically involves a static IP address)
That actually isn't the case. With OpenVPN you access the home network with DDNS account (such as noip.com or dyn). Noip offers a free service, which is convenient. You assign your router URL (perhaps martint92.ddns.net), and then you connect to the router using that name.
I believe ZeroTier handles this differently (without the need for a DDNS account). ReadyCloud also doesn't need DDNS.
aks wrote:
...consider the management and security implications.
This is of course an important consideration. You want to ensure that an encrypted connection is used, and you want to make sure there is some form of authentication. ZeroTier and OpenVPN use certificates for this. Some solutions (ReadyCloud for instance) use password controls - if your solution needs a password, make sure it is a strong one.
You can get some information on your password strength here: http://rumkin.com/tools/password/passchk.php It's probably best not to enter your real password, just something similar to what you are considering.
aks
Jul 24, 2017Virtuoso
Ah true, dynamic IP with DNS lookup service or static IP - I have used both. I found the static IP worked seamlessly, but dynamic lookup sometimes failed (I used a free provider), so for a business would a free DDNS work ok or would paid be best, or even a static IP which is also virtually free and guaranteed to work (my ISP charges £5 one off setup fee)?
- StephenBJul 24, 2017Guru - Experienced User
aks wrote:
even a static IP which is also virtually free...
My ISP (Verizon Fios) charges $20/month to get a static IP address. The basic business account (75 mbit service) is $85/month with a dynamic IP address and $105/month for a static IP address.
This is also limited to business accounts, they don't offer static IP addresses at any price to a residential customer.
- aksJul 24, 2017Virtuoso
In UK we seem to be getting a good deal (telephone line rental, unlimited 80Mbps broadband, any time/any number phone calls included for under £50 - I'm actually paying about £40/month right now)!
It would seem, in the US at least, dynamic DNS is the way to go.
- Martint92Jul 24, 2017Aspirant
It looks like I can create a Static IP from the routerlogin.net interface. This may just be my ignorance, but will that not suffice? Or do I need to purchase an IP from a provider to direct an outside connection to the network?
Not really. aks was talking about a static internet address for your router - that needs to be assigned by your ISP. The router can reserve addresses on the local lan, but that's something quite different. It is useful for port-forwarding, and in general I do think reserving an address for your NAS in your router is a good thing to do.
