tikitiki's avatar
tikitiki
Unexpected Network Error with NAS 102
I have a ReadyNAS 102, R8000 Router and Windows Surface PC - all running the latest OS versions.
I have had my itunes library on my NAS drive for years without any issues until the last few weeks.
Performance dropped to where itunes would freeze regularly and I am now getting problems copying any data/files over to the NAS and where I now get the 0x8007003B An Unexpected Network Error Occurred error.
I only get this issue when using wifi. When I am cabeled in to the NAS, it all works perfectly. Outside of the NAS issue my PC wifi is totally normal and runs things like general internet without any speed or connection issues.
My wifi is the 'ac' standard and Im connected to the 5GHz band.
Ive reinstalled the latest firmware on the router but that made no difference.
Online searching didnt really provide any answers - I have tried turning both the firewall and antivirus off but that made no difference.
Any ideas?
  • StephenB's avatar
    What apps and services do you have running on the NAS?  Have you checked the disk health?  How full is the volume?
    One option is to PM the mods - JohnCM_S and Marc_V - and ask them to review the NAS logs.
    • tikitiki's avatar
      tikitiki
      Hi
      Ive got 760GB free out of 1.8TB
      All the indicators on the NAS admin pages show 'healthy' or are green
      I dont run any other services or Apps. Its a pretty basic setup. I had the NAS antivirus on, but tried turning that off with no change
      Perhaps I'll try DM'ing and see what happens
      Some other things I forgot to mention are:
      Ive run SFC Scannow on my PC which found no issues
      I can stream from my NAS to my AV Reciever over wifi without any issue
      • Hopchen's avatar
        Hopchen
        Prodigy
        My post keeps failing to go through. Probably something to do with embedded links. I will send a PM.
        Error 1073741275 seems to be permissions related.
ProSupport for Business
