ken830
Jul 28, 2014Aspirant
Unprotected/Not-Redundant but all drives green/OK #23600013
I have a ReadyNAS NV+ v2 with four WD 4TB RED (WDC WD40EFRX-68WT0N0 3726 G) drives. I've been having a few problems with this unit and these drives that exhibit really peculiar behavior. Eventually, I...
mdgm-ntgr
Aug 04, 2014NETGEAR Employee Retired
Seeing you have a backup, I would go the route of a backup, factory reset (wipes all data, settings, everything) then restore your data from backup.
The issue could be fixed with some commands using mdadm most likely, removing disk 4 from SWAP and adding disk 2.
For complex issues paid support can be required.
