kiwibird2
Jul 09, 2019Aspirant
update of firmware on RN10400
My local admin page is stuck on saying "ready nas 6.24" This is a know bug thats fixed by loading newer firmware. The nas cant find ready cloud when the backup button is pressed. It is on a ne...
- Jul 10, 2019
There is no 6.24 firmware. Did you mean 6.2.4? If not, what firmware are you running?
It sounds like you are saying that the web admin ui remains on the splash page forever - is that correct?
- What browser are you using?
- Have you tried clearing the browser cache?
- Is there an ad-blocker running in the PC (or are pop-ups disabled)? Something like that could possibly block the admin login prompt.
kiwibird2 wrote:When I log into readycloud, I cant see the device.
ReadyCloud won't work with 6.2.4, so you'll need to update it to current firmware. You'll need to do that in three steps
There is some risk, so you should make sure you back up your data before you do these upgrades.
Jul 10, 2019Guru - Experienced User
kiwibird2
Jul 14, 2019Aspirant
This and stoping addblock plus fixed it. A very big thank you. Had this issue for some years and was very much stuck on it.
