skipb
May 15, 2019Aspirant
Update ReadyNAS 2120 firmware from very old version
I have a ReadyNAS 2120 that is currently at Firmware version 6.1.3.
When I looked at upgrading to newer firmware, there was this Warning:
ReadyNAS 102, 104, and 2120 systems must not be updated...
May 16, 2019Guru - Experienced User
So if I need to update to 6.2.5, or 6.3.5, where can I download those versions?
6.3.5 was only for the RN200 series; 6.2.5 says it is only for the RN100 (but I believe it should work for the RN2120). Hopefully one of the mods ( JohnCM_S or Marc_V ) will confirm which one you should use for your RN2120.
The download links are
https://kb.netgear.com/29498/ReadyNAS-OS-Version-6-2-5-RN102-RN104-Only
https://kb.netgear.com/29397/ReadyNAS-OS-Version-6-3-5-ReadyNAS-200-Only
FWIW, the KB articles should be updated, so it's clear which release applies to the RN2120.
- skipbMay 16, 2019Aspirant
Thank you for the links. But based on your other comments I should probably wait for more information on what the update sequence should be, specifically for the RN2120...
