skipb
May 15, 2019Aspirant
Update ReadyNAS 2120 firmware from very old version
I have a ReadyNAS 2120 that is currently at Firmware version 6.1.3.
When I looked at upgrading to newer firmware, there was this Warning:
ReadyNAS 102, 104, and 2120 systems must not be updated...
May 16, 2019Guru - Experienced User
So if I need to update to 6.2.5, or 6.3.5, where can I download those versions?
6.3.5 was only for the RN200 series; 6.2.5 says it is only for the RN100 (but I believe it should work for the RN2120). Hopefully one of the mods ( JohnCM_S or Marc_V ) will confirm which one you should use for your RN2120.
The download links are
https://kb.netgear.com/29498/ReadyNAS-OS-Version-6-2-5-RN102-RN104-Only
https://kb.netgear.com/29397/ReadyNAS-OS-Version-6-3-5-ReadyNAS-200-Only
FWIW, the KB articles should be updated, so it's clear which release applies to the RN2120.
skipb
May 16, 2019Aspirant
Thank you for the links. But based on your other comments I should probably wait for more information on what the update sequence should be, specifically for the RN2120...
