deploylinux
Jun 09, 2012Aspirant
Upgrade , fix, or replace readynas nv?
Hello all, I purchased a readynas nv with 4 x 750GB drives in september of 2006 (I think the amazon order was for ~$3K). Overall, I've been impressed with open community built upon the readynas, t...
deploylinux
Jun 10, 2012Aspirant
mdgm wrote:
Take a look at ReadyNAS Pro Series Performance
Personally I'd recommend upgrading to the Pro 6 but the choice is up to you.
Welcome to the forum!
Sounds like a good recommendation -- thanks for the extensive responses -- excellent community support. I'm curous though as I generally buy hardware that I expect to have a 7yr lifetime how much performance is going to be left on the table with ram of the pro units limited to 1GB, and no units with 10gigE by default, or even as an upgrade. If I knew the pro6 could have its ram upgraded to 4GB and NIC's upgraded to 10gigE later, that would make me feel much more comfortable shelling out the $ for something I plan to use for an extended period and not just replace a few years later.
Also, do the newer units have any kind of battery for the storage controller nvram? I wouldn't think that would add much to the unit cost given how old the tech is now - although I can see how it might a pain for customers who don't want to replace the battery every few years.
