pjlet
Aug 01, 2014Aspirant
upgrade capacity of RNDX4000
Hi
i have actually 4 hd 1 TO in xraid2
can i upgrade with hd wd 3 or 4 TO ? , perhaps 6 TO
is it possible to upgrade only one or two disk ?
thanks for your help
pjl
pjl
- vandermerweMasterYou need to upgrade 2 disks to get increased capacity.
You would need to do this one disk at a time, allowing the volume to complete a resync before upgrading the second disk.
Are there 6 tb disks on the HCL ? Can't view it at present. - pjletAspirantok thanks
i check the hcl list - mdgm-ntgrNETGEAR Employee RetiredWhat disks did you have installed when you last did a factory default?
