nasinneed
Nov 07, 2021Aspirant
upgrade for my Ultra 2 Plus
I have a ReadyNAS Ultra 2 Plus [X-RAID2] Firmware: RAIDiator 4.2.31 Memory: 1024 MB [DDR3] Volume C: Online, X-RAID2, 2 disks, 58% of 1841 GB used My friend has been running dutifily and without...
- Nov 07, 2021
nasinneed wrote:
If I upgrade the disks (I am more confident in the nas chugging > 10 years than any hard drives) I'm inclined to add them after the system is fully upgraded and allow the updated system to create partitions / filesystems / etc.
You can certainly upgrade the disks later on.
nasinneed wrote:
Plus I don't know if the OS v 4 will recognize newer hard disks.
It will recognize them, but there are some expansion limits on OS v 4. They were removed in OS 6.
Nov 07, 2021Guru - Experienced User
nasinneed wrote:
I have read here in the past that there is a[n] ... OS update I can apply to bring this into 2020's, but for the life of me cannot find the documentation.
You can convert the system to run OS-6 using the following procedure:
(Optionally) make sure the latest BIOS is installed before you do the conversion. To do this you install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS. Do this after you backup the NAS. This isn't necessary, but if you so want to update the bios it is easiest to do it prior to conversion
Basic instructions for the conversion itself are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
Netgear won't provide paid support on a converted NAS, so that is one consideration. There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
nasinneed wrote:
I have read here in the past that there is a memory upgrade ...
We do recommend doubling the RAM to 2 GB.
I've never owned an Ultra 2 Plus. Maybe first see that is installed.
My understanding is that it has only a single memory slot, and that 2 GB is the max it can handle. Look for PC3-8500 SODIMM (204 pin) memory. It needs to be single-rank.
nasinneed
Thank you!! This is fantastic stuff.
Another question: I will of course back this up/off first. Can I just pull the disks before the upgrade? Does the device even need the disks to run? Does the OS reside on the disks? I've never tried to read these disks (Seagate I think) from anywhere else, but I am assuming/hoping they are readable/mountable on another machine. I also may want to upgrade to 2x2TB or greater disks if the machine can handle that. 1TB disks were kind of a big deal 10 years ago.
- StephenBNov 07, 2021Guru - Experienced User
The OS resides on the disks, and the system boots from the disks. An install file is also placed in the flash - but that is only used during a factory install (or an OS reinstall from the boot menu).
The upgrade process requires disks to be in place. Though you could back up the system, remove the disks, and then do a factory install of 4.2.31 with a scratch disk. Then upgrade using the scratch.
But you'd still need to do a factory install on the original disks when you put them back (and restore the data from a backup).
- nasinneedNov 07, 2021Aspirant
Ah, I see.
If I upgrade the disks (I am more confident in the nas chugging > 10 years than any hard drives) I'm inclined to add them after the system is fully upgraded and allow the updated system to create partitions / filesystems / etc. Plus I don't know if the OS v 4 will recognize newer hard disks.
But maybe I would be making things more difficult than they are worth..
