nasinneed
Nov 07, 2021Aspirant
upgrade for my Ultra 2 Plus
I have a ReadyNAS Ultra 2 Plus [X-RAID2] Firmware: RAIDiator 4.2.31 Memory: 1024 MB [DDR3] Volume C: Online, X-RAID2, 2 disks, 58% of 1841 GB used My friend has been running dutifily and without...
- Nov 07, 2021
nasinneed wrote:
If I upgrade the disks (I am more confident in the nas chugging > 10 years than any hard drives) I'm inclined to add them after the system is fully upgraded and allow the updated system to create partitions / filesystems / etc.
You can certainly upgrade the disks later on.
nasinneed wrote:
Plus I don't know if the OS v 4 will recognize newer hard disks.
It will recognize them, but there are some expansion limits on OS v 4. They were removed in OS 6.
TallTomD
Jan 28, 2025Aspirant
I performed the upgrade, and it seems to have worked. When I attempt to logon to the NAS it prompts for password, but it will no longer accept the previous default password. I'm trying the old default:
admin
netgear1
Is there a new default password after the device is upgrade to firmware 6?
