hknas1's avatar
hknas1
Upgrade from Duo (v1)
Yes - I still have a Duo which has worked pretty much flawlessly over the years and even through and upgrade from a 1TB hard drive to a 2TB drive.
It's time to upgrade. Money is not a factor. Reliability and speed are the keys. I use the ReadyNas for two primary functions.
1. Run loss/flac music into a Sonos system as well as my high end stereo. I also drive itumes from the ReadyNas drives. (approx 1.5 TB of music)
2. Back up data from my iMac.
questions:
1. Two disk system or Four?
If 2, I will use 4TB hard drives.
If 4, should I used 4x 2TB or 4x4TB drives?
2. Which drives do you think work best and are most reliable?
3. Which ReadyNas - the new 200 series or the 300 series?
When I do upgrade, how do I move the data to the new drives? (just add the new system to my network and copy?, other?) (I've got Western Digital Sata drives but I'm not sure they are comparable with the 200 or 300 series (can't find a 2TB WD sata drive on the compatibility list).
All comments and any suggestions would be appreciated. questions seem simple and probably asked before but I had no luck searching prior threads.
Thanks
  • I'm in the process of doing this too.
    I've gone with a RN316 with 6x WD Red 4TB in RAID6. I missed out on the 6TB drives as they were added to the HCL about a week after I ordered my gear. I figured I would spring for the biggest drives available without excessive cost. 4TB drives should serve me well for a few years. I based my choice on cost per TB and a number of online reviews. I favoured NAS grade drives over desktop drives. Also, having read a number of articles and posts on the issue, I opted to go with a 6 drive RAID6 system as the the parity overhead is only 1/3 instead of 1/2 in a 4 drive unit. The risk of bad sectors increases with the larger drives, so I figured dual redundancy would give an additional layer of protection. I also have a cold spare available on site for immediate replacement should one of the installed drives fail. This should ensure that my array remains redundant while being resynced.
    As suggested by others, I have found importing data easiest and quickest by setting up a backup job on the new RN to copy data from the old RN or other NAS using WIndows / NAS timestamp protocol. This method also doesn't require any computer resources to move the data. You can also set up multiple jobs and they will execute one after the other without any further intervention (just hit start).
    My 2 RN Duo (V1) have both been rock solid and haven't missed a beat for more than 5 years. I plan to use them and other devices as backup stores for data served from the RN316. At some point in the future, I may add another RN316 as a backup device to provide some hardware redundancy as well.
    All the best with making your choice. OS6 provides so much more functionality over OS4.1. There are a few quirky differences that take some getting used to, but generally an enjoyable experience.
  • StephenB's avatar
    If money is not a factor, get at least 4 bays. If 4 TB is enough for now, get 2x4TB, and leave the other slots remaining for expansion. (2x6TB is also possible). Fewer/larger disks with empty slots gives you the best options for expansion later. Backup is needed even with RAID, so make sure you address that.
    The RN200 series will work quite well for your applications (and is a big step up from the RN100 series). The RN300 and RN500 series are also good options.
ProSupport for Business
