RD2KG's avatar
RD2KG
Follower
Sep 25, 2013
Upgrade from Duo v2 to RN10200 keep data?
My question is can I move the hard drive from the duo v2 to a new RN10200 and keep the existing data?
Or is there a migration plan that should be followed? Hard drive appears to be compatible with both NAS's
1 Reply
  • StephenB's avatar
    You cannot migrate your hard drive. You will need to backup your data and restore from backup.
    Or get a new drive for the RN102, and copy the data over the network via frontview backup.
ProSupport for Business
