prometheus1
Aug 19, 2010Aspirant
upgrade memory readynas ultra
anyone know how much memory i can shoe horn in the ultra 4 and am i likey to see much of an improvment in performance :D
prometheus1
chirpa wrote: 4GB may work, but could be a stretch on the chipset, haven't looked into that spec. But 4GB SO-DIMM is also very expensive right now, not really worth it. Probably cost less to get an Ultra 6, which uses desktop DDR2 DIMMs, much cheaper.
edit: chipset supports 4GB, via 2 slots. But the U4 only has one slot, so 2GB max.
thanks again chirpa.
i would think considering the duties the nas has 2GB will be sufficient but its shame there is not two slots
