prometheus1
Aug 19, 2010Aspirant
upgrade memory readynas ultra
anyone know how much memory i can shoe horn in the ultra 4 and am i likey to see much of an improvment in performance :D
mdgm-ntgr
Aug 19, 2010NETGEAR Employee Retired
It's probably a limitation of the size of the unit (can only fit so much into a small space). I believe the 6-bay ReadyNAS come with a 1GB memory module (you can replace this with a 2GB RAM module as chirpa said) and an empty slot for expansion.
