prometheus1
Aug 19, 2010Aspirant
upgrade memory readynas ultra
anyone know how much memory i can shoe horn in the ultra 4 and am i likey to see much of an improvment in performance :D
jmirabil
Oct 06, 2011Aspirant
chirpa wrote: 4GB may work, but could be a stretch on the chipset, haven't looked into that spec. But 4GB SO-DIMM is also very expensive right now, not really worth it. Probably cost less to get an Ultra 6, which uses desktop DDR2 DIMMs, much cheaper.
edit: chipset supports 4GB, via 2 slots. But the U4 only has one slot, so 2GB max.
I'd like to upgrade my Ultra 6 (RDNU6000 model) to 4Gb - this is supported.. yay!
Can I use the same 4Gb of RAM from the Readynas Pro Business in this RNDU6000 unit and then upgrade the pro business to 8GB (viewtopic.php?f=110&t=48085) I sure hope so.... :)
Thx -jmirabil
