rem11
Nov 21, 2012Follower
Upgrade Memory/RAM in RNDP600-200
I see I am a bit late to the game in upgrading my ReadyNas NV+ 4 with a Pro model. I have been doing some research and am having some difficulty finding RAM to upgrade the Pro model. I understan...
PapaBear1
Nov 22, 2012Apprentice
My usual recommendation to someone trying to increase the memory in their device is to match the specs of the original module as to speed and timing. That is of course not possible until after you purchase the device.
Going from 1GB to 8GB is a huge increase, and 8GB is the memory I have in one desktop that has a very fast processor and runs Windows and a lot of memory intensive applications. Is there a special reason you want to increase the memory? If you are only going to use it as a file server, you will see no speed increase as the speed limitation is the gigabit ethernet connection, which the Pro 6 is more than capable of saturating.
Keep in mind also that if you have a problem, as long as the unsupported memory increase is in place, technical support will most likely refuse support.
