megumi35
Oct 08, 2023Follower
Upgrade my ancient ReadyNas Duo advice?
Hi, I still have my ancient ReadyNAS Duo andI like to upgrade to a new system. I prefer to buy an dual HD device whichI can 'just' swap the HDs from my old NAS to the new one. If that is even possib...
Oct 09, 2023Guru - Experienced User
saudade wrote:
Well, I still run my Readynas Duo. It's not my primary storage.
I also still run my Duo (and an NV+ v1). But they are not primary storage, and I do not actually need them in my back-up plan. I just continue to use them as secondary backups because they still work. They are on a power schedule, and turn on once a week and back up selected shares from my main NAS (They aren't large enough to back up everything any more).
When they fail, I'll just get of rid them. Not sure if I'll invest in replacement disks for them or not - 2 TB drives aren't really cost-effective anymore. Drives appropriate for NAS in the 4-16 TB size range generally cost about $20/TB. Cost per TB is significantly higher for 1 and 2 TB models.
saudade
Oct 10, 2023Apprentice
That's how I do mine. Power schedule on once a week, then scheduled backups for specific shares on the WD, then power off.
My WD is 6TB total (4x2TB Raid5, 4TB free). The NG is 2x2TB mirrored. I have slightly over 1TB consumed). I already have a spare drive for each.
If the NG goes first, I'll "demote" the WD and replace it with something that won't go EOL so quickly. If the WD goes first, I'll replace it and still keep the Duo.
