Equinox1
May 05, 2020Guide
Upgrading from 5x2TB to 4x8TB on Readynas Pro 6
Dear all,
My current setup on the ReadyNas Pro 6 is:
- 5x2TB in Raid 6 for volume DATA
- 1x2TB in JBOD for volume SCRATCH
I now have a pack of 4x8TB WD RED drives looking at me.
At the same time, I'm getting some weird behaviours from the ReadyNAS (TimeMachine is very slow, cant log in via SSH, the users disappeared).
I'm currently running 6.10.1 and I feel like I should do a Factory Reset.
What would be the right migration path for this unit? My prefered end state would be:
- 4x8TB in RAID 6 for /DATA
- 1x2TB for /SCRATCH
And if possible, jump to 6.10.3.
Any ideas?
- 1x2TB for /SCRATCHOne option is to go with 4x8TB+2TB for the array with dual redundancy.
But since you are thinking you want to do a factory reset anyway, then maybe
- Export the scratch volume
- Power down and remove all disks (labeling them by slot).
- Do a factory default with 4x8TB and set it up as RAID-6
- Import the scratch volume
- Restore data from backup
- Equinox1Guide
But the current /DATA volume(5x2TB) is packed with the real 3,5TB of user data.....
If I do that, I lose the currenta /DATA volume.- StephenBGuru - Experienced User
If I do that, I lose the currenta /DATA volume.If you want to do a factory reset, then you need to back up the data. Hence step 5.
If you don't want to do that, then you could simply go with 4x8TB+2TB for the current DATA volume (expanding it). Though I'd still recommend doing a backup before doing that.
With that process, you'd hot-swap the new 8 TB drives one at a time, waiting for resync. You'd then need to create a new 4x6TB RAID-6 group using the new space, and concatenate it with the existing 5x2TB RAID-6 group.
You'd end up with an 18 TB volume instead of 16 TB.
