rhob
Jan 15, 2025Aspirant
Upgrading from OS6.1.8
Hi all. I have a ReadyNAS 312 that I bought un-used. It looks like it's on it's original OS, which is V6.1.8. Because of this I cannot access the admin page, as it displays "refused to connect". I've...
- Jan 16, 2025
I'm not sure why I didn't think of this before. A USB recovery to a higher version should work. Getting access to the GUI and doing a normal upgrade is still the better way, especially since I'm not convinced your problem isn't outside the NAS and an OS update won't fix it.
Sandshark
Jan 15, 2025Sensei
IE in WinXP should do it unless something else on your network is blocking it. Did you try direct connection to the NAS (which would require you set a compatible static IP address on the PC)?
Are you running RAIDar? Does it show the NAS and the correct IP address? Is that address in the subnet of your PC?
Did it come with drives, or are the ones in it yours? If it came with them, somebody may have changed the admin password from the default, so you should do an OS re-install.
Do you have another OS6 ReadyNAS, or access to one? Another way to update is to insert a volume that's on an updated version. The higher version "wins", and your chassis will be updated. Best way to do that would be to remove the drives from the other NAS (with power off) and then create a single-drive volume on one of the drives from the new one or any spare drive you have. Then power down and move the drive to the new one. When you power up, it'll go through an update, then re-boot into the updated OS. Then you can power down, put all the drives back in, and do a Factory Default.
NOTE to anyone else reading this: This is perfectly fine on the Intel-based 312. It would not be OK on an ARM based unit, as there is a mandatory upgrade path.
- rhobJan 15, 2025Aspirant
Hi. Yep RAIDar shows the correct product and IP. It's on the same subnet. I should have mentioned before that I tried a factory reset and OS install from the device and it made no difference. Password should have been reset to default.
Unfortunately I've only got the one ReadyNas.
