KaySee's avatar
KaySee
Upgrading from RN212 to RN214
Upgrading from my RN212 to a RN214 and want to migrate my two 6tb drives and add two more eventually.  The two 6tb drives are set up X-Raid.  Can I just take the two 6tb drive out of the RN212 and pu...
  • Marc_V's avatar
    Jul 04, 2018
    Hi KaySee
    Welcome to the Community!
    You can definitely do that procedure migrating both disks on another OS 6 Unit. You can check here Migrating a Volume
    Since the two 6TB are on X-RAID once you have added new disks it will expand and change it's RAID type automatically.
    Hope this helps!
    Regards
ProSupport for Business
