KaySee
Jul 04, 2018Aspirant
Upgrading from RN212 to RN214
Upgrading from my RN212 to a RN214 and want to migrate my two 6tb drives and add two more eventually. The two 6tb drives are set up X-Raid. Can I just take the two 6tb drive out of the RN212 and pu...
- Jul 04, 2018
Hi KaySee
Welcome to the Community!
You can definitely do that procedure migrating both disks on another OS 6 Unit. You can check here Migrating a Volume.
Since the two 6TB are on X-RAID once you have added new disks it will expand and change it's RAID type automatically.
Hope this helps!
Regards
Marc_V
Jul 04, 2018NETGEAR Employee Retired
Hi KaySee
Hope this helps!
Regards
KaySee
Sounds good, thanks for the quick response
- Marc_VJul 08, 2018NETGEAR Employee Retired
Hi KaySee
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
