MarcHermitte
Mar 20, 2023Aspirant
Upgrading HD on the RN42800-100NES
Hello! I have 8x8 HGST drives for a total of 64 TO on my 8 bays RN42800-100NES . I'd like to replace those 8 TB by new 16 TB HD but I', wondering if: 1) the new 16 TB HD will be recognized by the N...
- Mar 20, 2023
MarcHermitte wrote:
X-Raid, yes. 43.6 is the exact storage space I have.
Great.
MarcHermitte wrote:
1) the new 16 TB HD will be recognized by the NAS
Yes, as long as it is SATA (and not SAS). FWIW, the largest size I'm currently using myself is 14 TB, others here have reported success with bigger drives.
MarcHermitte wrote:
2) Can I replace the 8 TB hard drive progressively, letting the NAS the time to rebuild the missing datas as I only want to expand the total space of storage but not lose any data.
You can, though it will take longer (with a lot more disk i/o).
Expansion won't happen until you upgrade the fourth disk - when that resyncs the volume will grow by 16 TB to 64 TB. The remaining four upgrades will add an additional 8 TB per resync.
You don't actually need to upgrade all of them now, you could start by upgrading 4 and then do the rest later on as your storage needs grow.
It sounds like you might not have a backup for your data. If that is the case, I suggest putting some backup plan in place - either a second NAS, or a set of USB drives. Even RAID-6 isn't enough to keep your data safe.
Mar 20, 2023Guru - Experienced User
Are you using X-RAID? Normally 8x8TB would be set up for dual redundancy - a 48 TB volume (43.6 TiB).
MarcHermitte
