Esoteric
Aug 02, 2021Tutor
Upgrading my readynas
I've had my ReadyNAS for ages. I recently tried to swap out my drives to upgrade and it all failed. Luckily, there were some awesome people on here to help me out. After fixing everything I w...
Esoteric
Aug 02, 2021Tutor
Hey StephenB !
Not sure if you remember but you recently helped me here: https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Old-Legacy/Remove-inactive-volumes-after-hard-drive-upgrade-RN104/m-p/2121272#M16364
They got all of it up and running again with the three disks that worked. (Don't worry, I have a back up of everything now too!)
This 4tb disk is the one where it failed to resync and caused all my problems. Do I need to format it or something? It was a blank hard drive. I'm just trying to expand my space in my RN104.
Thanks!
Aug 02, 2021Guru - Experienced User
Looking again, the inactive volume is only disk 4. I am thinking it isn't actually blank - that it was formatted when you tried to add it before.
See if you can select that disk from the center graphic, and then reformat it.
- EsotericAug 02, 2021Tutor
That looks like it's going to work. Thanks. I just wanted clarification before I did anything after the last debacle!
The resync looks like it's going to take ages...
One other quick thing you may be able to help with:
When I do a backup to a seperate external drive, it says it fails to backup any of my .dmg files (that are old programs for Mac). It will back up everything else.Is this normal thing that's excluded (.dmg files)? I understand if you don't know, but thought I would ask. They're old, so not that important... I'm just curious why they would fail and everything else would work.
Thanks again my good man.
- StephenBAug 02, 2021Guru - Experienced User
Esoteric wrote:
When I do a backup to a seperate external drive, it says it fails to backup any of my .dmg files (that are old programs for Mac). It will back up everything else.That should be working. How is the external drive formatted?
I formatted it to FAT32 using Disk Utility on my Mac.
